DJI Paladin
Hi there. Thank you for reaching out. Kindly please refer to the DJI FPV Cruise control introduction below:
1. Cruise control is only available in Sport mode and not available in other modes (such as Normal mode or Manual mode).
2. Press the Start/Stop Button to enable the aircraft’s cruise control. Press the Start/Stop Button again to disable cruise control.
3. No initial speed is required when the DJI FPV aircraft is in the forward direction. After enabling the aircraft’s cruise control, push the pitch stick to increase the speed to 5 m/s and then release the stick. At this point, the aircraft will move forward at a speed of 5 m/s. After cruise control is disabled, the aircraft will decelerate to 0 m/s and hover.
(If the initial speed of the aircraft is 3 m/s, the aircraft will keep moving forward at a speed of 3 m/s after cruise control is enabled. After cruise control is disabled, the aircraft will decelerate to 0 m/s and hover).
4. If the aircraft is flying in a windy environment or its flight is controlled by a control stick, the horizontal speed displayed on the screen will change correspondingly.
In addition, regarding the control tilt range for the DJI FPV gimbal is -50° to 58°.
Notes: When the accelerator is pressed to make the aircraft fly, the gimbal tilt cannot be controlled. The aircraft will lock the gimbal angle. Based on this angle, the orientation will not change. The aircraft will lock the gimbal angle, which will not be changed following the flight orientation. |
