LV_Forestry
Flight distance : 4726654 ft
Latvia
KutluhanG Posted at 6-4 13:25
Thank for the code. If you are the one who write the code can you tell me how does djı_irp.exe is working and how reliable is produced images.
No I did not write the code. It is available on the DJI website. Thermal SDK something like that.
I'm not going to give you the answer, you will search, it will be more profitable for you later.
I put you on the way. Look at how many bits the raster image is encoded. Look in the metadata of the image, there is an indication concerning the temperature. Use QGIS to interpolate data.
You will see it is very simple.
If you still can't find it, don't hesitate to ask.
Keep in mind that the nature of the material affects the temperature read. Especially in the case of electrical connectors which are often protected by plastic or worse, glass. H20T is a good camera but in terms of settings it is very limited. |
