LV_Forestry
Flight distance : 4726654 ft
Latvia
OK, I see. It seems to be a bug. I have a dataset without RTK and it is the AMSL altitude (ortho) that is displayed. It seems that when you put the RTK module, it goes into HAE. But in the EXIF it retains the designation Above sea level.
You can do the test, do a flight mission with the RTK module connected to the centipede network. Redo the same mission by removing the RTK module. If we follow this reasoning you should have two offset dataset of the geoid value at this place.
There is indeed a moderator who will find an answer for us. Otherwise you send an email to enterprise@dji.com, remembering to share the answer with us.
