Johnnokomis
Flight distance : 13349895 ft
Mobilehomer Posted at 6-13 17:51
Yeah, really. A quote from YOUR post #13 - "You're looking and giving suggestions from a photographers perspective, which this drone isn't meant for."
And..? My quote there is still an accurate statement. That doesn't mean I agree or am happy about it though. This whole thread's main question was about aperture priority mode with ISO control as well. Obviously OP wants to lock ISO at 100. The M3E won't go above 100 ISO unless you take away most of the available lighting anyways. So OP's wish is already implemented.
Now back to you.. Here's your quote - It's not designed to make beautiful photos and videos, it IS designed for inspections, mapping, SAR - things of that nature.Lets expand on this, here's a reason for just some of the missing features that would still pertain to what you named.
- White balance - Mapping needs control or atleast be able to lock in a value. When it changes halfway through a mapping mission the ortho (which is the main deliverable) is rendered completely unaceptable as the photo above proves.
- Frame Rates - Videogrammetry is a normal use case for a "work drone" as you like to call it. 60 fps would mean twice as many frames to work with. Also, jobsite videos taken with the M3E won't fit right on the standard 24 fps timeline. If you want to follow the proper 180 degree shutter rule, doubling your frame rate to 60 could be useful.
- Video resolution - Do I need to explain the benifits of higher than 4k videos?
- Smart Tracking - SAR, border patrol, law enforcement, inspections and many others would benefit from this feature. Thats why there's many different post on these forums asking why this is still missing.
- Quick Transfer - Jobs. Have. Deadlines. Strict ones at that. The faster data is off the drone and being processed, the faster the user gets a return on their investment.
- Master Shots - This one isn't as important, but after a small company spends 5-10k on a new UAS for the first time they are rightfully skeptical. A smoothly edited compilation of a jobsite before the pilot even leaves will make them sleep better at night.
