Sean-bumble-bee
Flight distance : 15997 ft
Probably because you haven't performed the correct search or looked in the right places. I found both with a google for "DJI Mini 3 pro replacement front arms".
BTW are you aware that any NEW parts are probably going to be pattern parts? As far as I know DJI do not make such parts available to the general public.
Besides it may be tricky to swap over the motor, antenna/e and wiring.
If you end up getting an arm and motor ensure that the motor is for a Pro. The non pro motors lack the blade mounting boss of the pro motors, they may be interchangeable but you would need the different screws used with the non pro drones. |
