Flying Below Take Off Point
4240 14 2023-6-16
Hesvey Martin
Flight distance : 192825 ft
Philippines
Hello DJI Team! I'm a newbie Mini 2 user here from the Philippines. I would like to ask if is it possible to fly our Mini 2 lower than where it took off like when you are at a roof deck and you want to fly your drone around ground level or like you're on a hill top overlooking the sea below and you want to fly your drone a little closer to the waters. In doing so, will it indicate a negative (-) elevation in the fly app? Thank you in advance for your responses! Fly safe everyone!
2023-6-16
JJB*
Flight distance : 13811834 ft
Yes. possible to fly lower.
Height shown in the fly app shows than negative numbers.
Barometric height is sett to zero at takeoff, so all heights are referenced to takeoff height.
cheers
JJB
2023-6-16
hesveymartin
Philippines
JJB* Posted at 6-16 09:48
Thank you very much for that, JJB! have a great day! #flysafe
2023-6-16
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Yes, you can but please ensure the safety. We highly recommend you keep the drone within your line of sight to guarantee safety when flying. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
2023-6-16
Sean-bumble-bee
Flight distance : 15997 ft
One point, be wary of flying the drone down into gorges or canyons where the drone's view of the sky might be restricted and GPS lost, that can lead to 'complications'.
2023-6-17
hesveymartin
Philippines
hesveymartin Posted at 6-16 12:14
Thank you for that reminder. I will make sure that the aircraft is on my VLOS. Appreciate that! Thanks
2023-6-17
hesveymartin
Philippines
Sean-bumble-bee Posted at 6-17 02:31
Complications like automatic activation of RTH, right? I will take note of that as well! thanks!
2023-6-17
Sean-bumble-bee
Descending below the take off point makes no difference to RTH.
BUT what you would need to be careful of is, if, for example, you initiated an RTH whilst the drone was within any of the applicable horizontal-distance-from-the-home-point thresholds and that behaviour changes from model to model so you need to be sure you know what the drone's manual says.
For the mini 2
"If the aircraft is less than 20 m from the Home Point when RTH begins, it will hover in place and not
return to home (firmware version v1.1.0.0 is required. Otherwise, the aircraft will land immediately).
If the aircraft is further than 20 m from the Home Point when RTH begins, it will return home at a horizontal speed of 10.5 m/s."
However losing GPS would prevent an RTH.
"The aircraft cannot return to the Home Point if the GPS signal is weak or unavailable. If the GPS signal becomes weak or unavailable after RTH is triggered, the aircraft will hover in place for a while before landing."
2023-6-17
Labroides
Flight distance : 26781877 ft
Sean-bumble-bee Posted at 6-17 07:08
Descending below the take off point makes no difference to RTH. BUT what you would need to be careful of is if, for example, if you initiated an RTH whilst the drone was within any horizontal distance from the home point thresholds and that behaviour changes from model to model so you need to be sure you know what the drone's manual says.
For the mini 2
The OP made no mention at all of flying down into narrow canyons.
None of what you are discussing has any effect on what he is intending.
You are just confusing him unnecessarily with things that are irrelevant..
2023-6-17
Sean-bumble-bee
Labroides Posted at 6-17 14:36
You are just confusing him unnecessarily.
Whilst it is true that they made on mention of flying of flying down into a gorge, tall buidlings can create gorge like enviroments.
As has been commented on in other threads where people have been told "flying between tall buildings can lead to loss of GPS by reducing the total number of satellites visible to the drone and or their spread.
Might you have made such a comment in the past?
Aside from that I think forewarned is forearmed.
I'd rather waste the time it took me to type the text than have the OP come back and start a "I lost my drone because it lost GPS and couldn't climb etc."
Either way, it's done now.
2023-6-17
Labroides
Sean-bumble-bee Posted at 6-17 14:58
And he made no mention of flying between tall buildings either.
His question was plain and simple.
No, I wouldn't have unless it was relevant.
So you want to warn of every possible incident regardless of how relevant it is to the question?
Forewarned of things that are irrelevant just confuses people.
But you didn't warn him about flying downwind in strong winds, or about preventing yaw errors, or a dozen other things that might cause a problem.
Perhaps you should type up a five page essay and have that on hand to copy and paste just to cover all the bases whenever a new flyer asks a simple question?
2023-6-17
Sean-bumble-bee
Labroides Posted at 6-17 15:35
Jesus wept Labroides get a grip and stop being such an ...........
I didn't even bother reading all the way through it.
You post some good stuff at times and completely torpoedo any esteem you might gather with crap like this.
2023-6-17
Snoopy70
Flight distance : 6043002 ft
Also, I once tried flying down into a mine shaft, and suddenly the drone started initializing landing. So I stopped descending, and came back out.
2023-6-19
djiuser_Nk6zmAOeyD84
JJB* Posted at 2023-6-16 09:48
the probleme is the as sonn as i go down to 1.5 M it triggers automatic landing.  i know there is a cancell button but as soon as i go lower it triggers again.How to prevent automatic landing ?
2024-3-13
JJB*
djiuser_Nk6zmAOeyD84 Posted at 3-13 12:19
Autolanding is normally inititated at 0.5 meter IR height AND with RC stick down.
If IR sensor measure a False (lens dirty or wet etc) height og 0.5 meter....autolanding will happen also.
So 1.5 meter is not normal....sure about this 1.5 ?
Better to share your flightlog for this issue
cheers
JJB
2024-3-13
