Propeller screws won't budge
12Next >
5836 42 2023-6-18
cmhawke
I was planning to test-drive the drone outside on a hike tomorrow, after unsuccessful indoor flights led to crashes and propeller damage. I had bought replacement propellers. I have managed to unscrew all the old propellers except 3 that won't budge. I tried using 3-in-1 multi-purpose oil and WD-40, and/or a power drill, either or both of which have always worked before for similar situations involving stuck parts.
I attached photos of the drone with the propellers that are stuck due to the screws that won't budge, and a photo of the propellers that I was able to remove.
Would the remaining propellers cause issues if they are left on, if I otherwise put new propellers on the rest? If they would cause issues, how would you advise I proceed at this stage?
3 propeller screws stuck on DJI Mini 3 Pro
2023-6-18
Burt37
Flight distance : ****
Have a look at this thread, post n2 it may help...
https://forum.dji.com/forum.php?mod=viewthread&tid=292487
2023-6-18
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
It is necessary to replace the whole, the entire pair
2023-6-18
Sean-bumble-bee
Flight distance : 15997 ft
The blade on the front motor would most definitely need changing, Not only are there chunks missing but, for balance, they are in the worst possible place, the outer end of the blade where they will cause the greatest 'centrifugal' imbalance possible.
Blades are weight matched pairs and if one blade on a motor is change its companion should be changed too, both new blades should be from the same new pack. I'd say the rear blades should also be changed.
2023-6-18
Bashy
Flight distance : 2354357 ft
You need a decent screwdriver, the one that comes with the drone isn't the best
2023-6-18
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the incident that happened to your drone. You may consider sending the unit in for a proper diagnosis. You may submit a ticket case at https://repair.dji.com/repair/index  . Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. Thank you for your understanding and support.
2023-6-18
Blackbuckone
Flight distance : 126191 ft
Burt37 Posted at 6-18 15:47
I was just going to suggest check out my post from last week, well done.
It's a tricky and fiddly thing to do, but it worked without causing any damage.
Cheers
2023-6-19
AsturianCetorix
Flight distance : 46814 ft
Those little screws have some glue on them, use a better screwdriver. The DJI one is very convenient, but it´s far to be a good one.
You should always change the propellers in pairs, not one at at time.
If the soft orange rubber is tamaged, it would cause some vibrations.
2023-6-19
DowntownRDB
The DJI-supplied screwdriver is unfortunately of terribly inferior quality and not up to the job, especially with the factory loctite on the screw tips.  I caught the Wowstick 1F+ on sale and use it without issue.  I've since thrown the DJI supplied screwdriver into the trash bin.
2023-6-19
DroneApe
Flight distance : 459954 ft
For the Mini 3 Pro, I read that DJI recommends a PH0 screwdriver.
A high quality PH0 screwdriver is in the link below.
https://www.wihatools.com/produc ... ampaign=sag_organic
2023-6-19
Bashy
Oh, another way is to heat up the screwdriver, till its quite hot, then put it on the screw and wait a moment or two for the screw to heat up and inturn soften the tread loc stuff..
2023-6-19
cmhawke
There were 3 props left.
The Wera screwdriver either helped get 1 off, or it was already loosened from the oil and WD40 applied earlier.
The other 2 still wouldn't budge. I cut off the bulk of the props using scissors so they wouldn't get in the way. I tried a screw extractor set, but it did nothing.
I figured using the hammer + screwdriver trick could damage other components of the drone.
So I decided to go the exacto + plier root. But I don't see how the remainder of the props can be effectively cut, based on how close they sit to the drone, the angles required for cutting, and the prop material being quite thick for the knife. Earlier, the scissors actually seemed much more effective for cutting the bulk of the props off than the knife, but obviously scissors are not an option for the prop remainders.
Thanks for any suggestions on this.
2023-6-24
Andre Laf
you could cut the rounded ridge off with a dremel and then use pliers or vise grips on the screw head to get it out
2023-6-24
cmhawke
Andre Laf Posted at 6-24 17:01
Now used these:
Klein D275-5 precision flush cutter:
It slowly flaked away at the remaining prop plastic, otherwise didn't do much else. I aimed for the head but inconvenient angles and/or lackluster function seemed to prevent precise cuts.
Dremel 4300 5/40 with metal cutting wheel, with a plier to hold the gray motor bits in place:
It slowly eroded the remaining prop plastic but after a few minutes seemed to reached a standstill; didn't notice further erosion. 5,000-15,000 RPM.
Used pliers throughout to turn and yank at the screws.
I'd be sending it to DJI as a next step.
2023-6-25
Andre Laf
I would have cut the plastic away from the top ridge towards the screw ,then you could have been able to grip the screw head better and remove . There is no way the screws are that tight that they can not be removed ,they would have to be welded .
2023-6-26
Burt37
What a huge waste of time... All you needed to do was get a pair of these and just grab the first 2-3mm of the blade crushing the plastic against the edge of the screw head... Both the blade and the screw are already screwed, so it doesn't matter. The important thing is not to damage the blade holder and screw retainer... It is a 10 seconds job!
Why you guys always overcomplicate things so much.... Did you even ever read the link? Sean gave you the solution, but you need to read it...
PS
Use the quick grip from the top not from the side, otherwise you are grabbing too much material...
2023-6-26
cmhawke
In reply to the last two posters, I tried both of those already.
Like I said, for a few reasons, could not get enough plastic off the top to expose enough of the screw head to do anything else.
Also, based on the thread Sean linked to, it took the person 3+ hours, not 10 minutes... I don't currently have the time to try that for 3+ hours to see if it works for me or not.
2023-6-26
Burt37
cmhawke Posted at 6-26 18:05
You don't need to take the plastic off...
You crush the plastic with the grip while also grabbing the edge of the screw... You do know how quick grip do work?
You probably are right... It is less than 10 second...
I'm only talking about Sean suggestion of using the Quick Grip pliers... That is what I normally do. I only use the screw driver to put the new blades back on...
2023-6-26
Andre Laf
but Burt is correct I would have just used the vice grips from the top straight down or from the side  and tighten until it grips the screw head, then hold the motor with other hand and unscrew the screw take a minute at the most.
2023-6-27
mhawke
I had used a grip around the side, crushing and rotating but it wouldn't turn. Hadn't tried top-down angle. I'm going on a trip for a few weeks and will have another look when I return.
2023-6-27
Blackbuckone
cmhawke Posted at 6-25 21:03
Now used these:
Do what I did and what's recommended earlier in the thread when I had the same problem.
Shave bits off the plastic stalk around the screw with a Stanley knife until you can grip the screw and crush it together, shave squeeze, shave squeeze. Once you've done enough you should be able to grip the screw (I used small wire cutters) and slowly turn it out bit by bit
That's what I did with mine, the Phillips screw thread had turned totally round and it wasn't budging.
Do a test flight first once the two new props are on, and another big tip which you've already learned - DON'T FLY INDOORS - you are asking for trouble and breakages.
2023-6-27
mhawke
Blackbuckone Posted at 6-27 16:25
I tried a few Stanley and exacto knives and none were very effective against the robust plastic. Also difficulty in the precision required to shave off the top of that blip. But I will continue looking into this after my trip.
2023-6-27
Sean-bumble-bee
I think there is a 'risk' that if you crush too far down the blade's hub you will make the hub grip the boss that projects from the top of the motor, any crushing of the blade's hub should be limited to that bit that of the hub that surround JUST the head of the screw.
2023-6-27
Burt37
Sean-bumble-bee Posted at 6-27 19:26
Correct...
If you go too far down from the top, you are just making it harder for yourself...
The quick grip has so much more torque than the little screw driver. It really doesn't take much to lose the screw but you need to crush the plastic, as in, put some preload on the quick grip... Lots of people don't know how to use them. It should be hard to close the grip, but not too hard...
Another option is to start the screw with the quick grip and then complete the removal with the screw driver... That's what I normally do and it does takes around 10 seconds to remove the screw (that you get spares with the new blades anyway)
2023-6-27
bobmalkh
Flight distance : 88045 ft
Israel
DroneApe Posted at 6-19 13:38
Thank you for your advice)) I just threw $20 into the wind. This screwdriver does not fit. Need PH00. And it is better not to advise until you try it yourself.
2023-7-4
Sean-bumble-bee
bobmalkh Posted at 7-4 04:21
It may not even be Phillips, have a look at https://en.wikipedia.org/wiki/List_of_screw_drives
2023-7-4
bobmalkh
Israel
Sean-bumble-bee Posted at 7-4 04:34
I ordered another "00", as soon as I receive it, write what and how
Thank you
2023-7-4
DroneApe
Here's the thread where DJI recommends the PH0 for the Mini 3 Pro.    I was going to reply to his snarky comment, but my New Year's resolution was "don't go there".  lol
https://forum.dji.com/forum.php?mod=viewthread&tid=285090
2023-7-5
SeehawerB
Flight distance : 5710653 ft
PH00 and PH000 both fit, had this topic with IANinLondon recently. He took the PH00 and suggested it in one of its videos, I read PH000 somewhere and used this successfuly.
For the future: IF a proper fit screwdriver with sufficient force down while trying does not help, I would suggest using a heat gun carefully set to max. 70 degrees celsius and heat up the aluminium to weaken the screw lock varnish. Sadly if I would be in your position I would consider sending the Mini 3 to DJI for repair. New motor.
2023-7-5
bobmalkh
Israel
The WIHA PH00 screwdriver fit perfectly. Once again I was convinced that the standards are different. Until you experience it for yourself. Now I have checked and can recommend this firm
2023-7-5
rsl2022
Flight distance : 5308 ft
Come on DJI, no one should have to use mole grips, Stanley knives, heat guns, Dremel cutting disks, or return for service just to remove props.  Are you doing anything to address this please?  It could be as simple as a different screw supplied with new props.
2023-7-5
Lieutenant
I haven't needed to replace any props yet, but I prob will in the future. I can see from everyone else that the screws are too soft (faulty manufacture), and that's reason for a recall in this case.
What I'd like to know is : If my drone is out of warranty and I need to send it in for a stuck screw, who's going to pay for it ?
2023-7-6
bobmalkh
Israel
Lieutenant Posted at 7-6 01:03
really interesting question ;)
admin, what do they say in the office of DJI?
2023-7-6
Burt37
That's a bit of a turn around from this other yours previous post:
"I bought a PH000 screwdriver and it was way too small.
I then bought a quality PH00 screwdriver and it fits perfectly.
I haven't actually needed to remove any propellers yet so I hope it works as it should, but the lesson here is buy quality tools to get the job done.
And you are right. With the proper Ph00 and the understanding of what you are doing, like holding the screwdriver perfectly perpendicular to the screw, put enough force, so the tip doesn't jump out and a basic mechanical understanding of how a metal, teflon coated, tiny screw works, it has never been a problem.. But I wouldn't use this thread as a measuring tool for how hard or easy it is to remove a screw..
In the DJI office I would say they are on the floor laughing out loud...
If Henry Phillips could read this thread, he would probably cry....
2023-7-6
bobmalkh
Israel
Burt37 Posted at 7-6 03:41
yeah, it would be funny if it wasn't so sad...))
2023-7-6
SeehawerB
@burt37
'With the proper Ph00 and the understanding of what you are doing, like holding the screwdriver perfectly perpendicular to the screw, put enough force, so the tip doesn't jump out'
That is very important. The screwdrivers tip has to match the screw, it should feel like a tight fit if it slips in and you have to hold it perpendicular and issue a pressure down into the screw while you carefully try to loosen the screw. There are many catches in that. Especially philipps screws are a bit challenging if it comes to rather weak materials and hard-to-move threads. If the screwdriver slips over only one time, in most cases you have lost the screw then.
2023-7-6
Sean-bumble-bee
Rather than a recall, I think a better idea would be for DJI to publish the cross-slot's type and size !
2023-7-6
djiuser_Peter
Flight distance : 6568 ft
Did you manage to resolve it?
2023-7-6
Burt37
Sean-bumble-bee Posted at 7-6 07:03
And perhaps letting the customer know that even if it is a very simple operation, because of the size of the screw, it can be easily damaged if the tool is improperly used while trying to remove the screw...
2023-7-6
Burt37
bobmalkh Posted at 7-6 05:29
You are 100% correct. There is no better way to describe it...
2023-7-6
12Next >
