greystoke.eng
Flight distance : 1829121 ft
Actually many radars are in the UHF band, especially longer range ones. They have a very tight transmission pattern with one main lobe and some smaller side lobes depending on how well designed the antenna is. If you fly in the plane of transmission, you will be blessed by the high power main lobe. The antennas, especially the 3cm one rotate very fast and the 10 cm one much slower. This is due to the operating range, longer out to target and back, so you don't want the antenna rotating out of the return signal at max range. The radar I had on my aircraft in the service would range 250 miles, rotated at 22 times a minute and could kill seagulls at 600 meters. It was very un-healthy to humans, usually causing death onboard ship if it happened to be turned on by accident. It had many interlocks. Same went for the high power ones, like the SPY-1 and SPS 48. One of the many reasons they are kept high on the mast. My quartermasters, when I was a midshipman, would refuse to go on the upper signal bridge if we had any operating radar. Clever guys. |
