Mini 3 Pro flying over beach
1007 24 2023-7-10
SnowSkier Pilot
Portugal
Hi there!
Small flight last sunday, late afternoon and after sunset with Mini 3 Pro over the beach, very close to my hometown.
Sorry about the green cast at the corners of the frame and also the reflections caused by the sun. These freewell filters are no good.
2023-7-10
Blériot53
Flight distance : 6188465 ft
Nice open space to fly over. Not so much the green tint that was barely noticeable, but quite a bit of the footage looked fuzzy and out-of-focus.  Do you ascribe that effect to the filter you were using as well?
2023-7-10
Montfrooij
Flight distance : 2560453 ft
Blériot53 Posted at 7-10 22:41
This is caused by the slow shutterspeed combined with faster motion.
I commented on this in another thread too.
I personally feel that a faster framerate (which will allow for a faster shutterspeed) does work better with fast motion.
Unless you're aiming for this blurred look of course
2023-7-10
Montfrooij
Nice video man.
I think I kind of like the color cast, but it is baked in, so that is a bummer.
2023-7-10
Blériot53
Montfrooij Posted at 7-10 23:24
I've been shooting in 30FPS rather than 25FPS for just that reason.  Maybe I should increase it even more.
2023-7-10
Montfrooij
Blériot53 Posted at 7-10 23:31
Technically, in PAL area, the 25-50 framerates are considered 'better' but this is only true when you shoot something with artificial lighting.
Since that can flicker because of the grid frequency.
I made a test some time ago.
2023-7-10
Blériot53
Montfrooij Posted at 7-10 23:47
Yeah, pretty conclusive.
2023-7-10
DAFlys
Flight distance : 95125112 ft
Nice flight,     which freewill filters are they??  I was in the market to get the VNDs they sell.
2023-7-11
DowntownRDB
Flight distance : 1722 ft
Nice location.    I use Freewell filters on all my drones and have no issues with them.
2023-7-11
SnowSkier Pilot
Portugal
Well, from where I stand, I mean my monitor, the video is clear and sharp, except when I turn the drone left or right and also at the bottom of the frame, probaby due to the ND64 Freewell filter I was using at the time. Also, some shots were made in sport mode and maybe too much fast turns that increases blur when you're using an ND64.
Everything else is fine.
I must say, and that's a repetion of what I said in some other thread, these freewell filters compared with PolarPro are useless, at least for me, because I've used polarpro in my Mavic 2 Pro and I never had this problem. I must say also that I've never used a ND64 on the Mavic. The maximum I've used was ND16
So, in conclusion, maybe I was flying too fast for this filter. Next time I'll use the ND16. I've used the ND64 due to the fixed aperture of 1.7 and with lots of light from the sun, despite it was already 8 PM made this happen.
One more thing I've noticed with this filter and others that I bought from freewell, they reflect a lot the sun lights and this never happened with polarpro even when I was flying against the sun light. Of course the image was over exposed when I flew directly, but I've never had reflections.
2023-7-12
SnowSkier Pilot
Portugal
Hi,
I did that test already on the field, I mean, using at daylight 30fps and 1/60 shutter speed and at night, 25fps and 1/50 shutter speed. Both in PAL and NTSC. In these modes the video went smooth and perfect.
These are the only frame rates I use.
2023-7-12
SnowSkier Pilot
Portugal
DAFlys Posted at 7-11 00:44
Hi,
I was using the ND64 with polarized filter
2023-7-12
SnowSkier Pilot
Portugal
DowntownRDB Posted at 7-11 01:56
Well, you're a lucky guy!
I have to spend more money to buy the PolarPro pack I should have bought prior tho these ones of Freewell.
One question...are your filters polarized or just simple?
2023-7-12
Blériot53
SnowSkier Pilot Posted at 7-12 10:30
I've just watched again, making sure that it wasn't a wifi bandwidth issue, since I have a pretty high-end monitor screen. It was just the same - clear enough in centre-frame until making turns.
I hope you get it sorted to your satisfaction. I understand your conclusion regarding the filters.
2023-7-12
SnowSkier Pilot
Portugal
Blériot53 Posted at 7-12 11:08
Hi,
Yeah, that's exactly what I can see, sharp in the centre and blurry in the corners and when I'm turning the drone.
I have this drone for almost a month and i've used it just for a coupe of times, making tests at day and night, just to find out what's the best modes and frame rates for filming. I'm going to use it only on my travel trips, since it's small and lightweight. For other type of work, more semi-professional,  I'll use the Mavic 3.
Thanks
2023-7-12
Blériot53
SnowSkier Pilot Posted at 7-12 14:10
Hi,
2023-7-12
DAFlys
SnowSkier Pilot Posted at 7-12 10:44
Hi,
Cheers I will certainly avoid those.
2023-7-12
Montfrooij
SnowSkier Pilot Posted at 7-12 10:43
Hi,
Combining both 25 and 30 fps in one video will give problems of skipped frames, so I stick to 25-50 (or 30-60 in NTSC countries) so I can combine my footage
You can slow the 30fps footage down to 25fps to avoid this, but that creates an effect that is not always wanted (slight slow motion)
2023-7-12
DowntownRDB
SnowSkier Pilot Posted at 7-12 10:46
Not polarized.  I have some PolarPro filters and they work well also.
2023-7-13
Mini-G
Flight distance : 663304 ft
Hi,
Firstly, I should say, great footage! The location adds to how wonderful it all looks.
I use Freewell filters all the time, and I don't normally see much colour tint. However, I do use the D-Log colour profile
What Colour profile do you shoot in?
The other thing to check is the position of the line on the filter.
I've found that if this is in the wrong spot, the polarising effect is invalid or too strong.Also, I don't use the CPL supplied in the Freewell all-day pack, as the colour tint is on the green side, just like in your video.
2023-7-13
Black Sea Drone
Flight distance : 1362336 ft
Bulgaria
nice flight and beautiful place , continue the good work
2023-7-13
ro_walker
Brazil
Nicely done!
2023-7-13
dimidrone
Flight distance : 2116302 ft
Latvia
Nice low ride!!!
2023-7-13
djiuser_h24GwhGpRk8S
Flight distance : 51486 ft
Greece
Very creative
2023-7-16
SnowSkier Pilot
Portugal
Thank You all for your comments. I really appreciate it
2023-7-18
