spaceman5
Israel
Hi
The product page (and manual) of the Action 3 recommends using a microSD card that is
"UHS-I Speed Class 3 rating".
Indeed, I bought a Samsung PRO Plus microSD card,
which supports 120MB/s Writing, and 160MB/s Reading.
I then did some real life tests with the Action 3, using the resolution that I use (1080p),
and my Video BitRate results in 1080P are:
30FPS: 5MB/s
60FPS: 8MB/s
120FPS: 10MB/s
Please note: I use h.264, and not h.265
As can be seen, it needs between 5MB/s and 10MB/s, when you're on 1080p.
So as can be understood, the really high Writing Speed requirement from your microSD card
is only needed if you go to 4K for example, which I never do.
Due to this, I would like to suggest something:
A known problem with video compression codecs, is that If you have many small details in your image,
for example leafs, grass, or things like that,
then you get a "smear" effect on your image.
This can be prevented If you use a higher BitRate
(meaning less compression) for the video data.
Currently the Action 3 does not have a Bitrate setting.
Obviously, for 4K this would be more difficult, since 4K already uses more MB/s,
but for lower resolutions, such as 1080p, and 720p (if you take my recommendation
from the previous thread that I created, about adding 720p),
there's a lot of extra MB/s that we can use with the microSD card,
and thus we can get a better (less compressed) video.
This is especially useful for people who take the video they filmed with the Action 3, and then Edit it with a Video Editing software.
The Video Editing software eventually exports the video, meaning re-compresses it,
and that re-compressing makes us lose more quality.
So preferably the source files that the Video Editing software gets are as less compressed as possible..
So can you please consider in your next Firmware Update, to add a Setting for BitRate?
At least for the lower resolutions (1080p, and 720p If you add that too).
The microSD card has a lot of spare MB/s that can be utilized for that purpose, in those resolutions..
Thank you very much
