I can take pictures and videos no problem. As soon as i go into quickshots, I'm able to draw a square around myself but then the start button is faded out green and won't let me click. Same thing happens with panaromic pictures as well. Please help!!!! Going to Mykonos tomorrow
I've updated and restarted. IDK what I'm doing wrong.
Hi, DTL. Thank you for reaching out Please try the steps below:
Please confirm whether it is the latest version of the App.
1. For drones without internal storage, check whether a microSD card has been inserted. For drones with internal storage, check whether the selected Storage Mode has sufficient storage. Mini 2 doesn't have internal storage, we recommend using an SD Card and make sure that the storage selected under settings is SD Card.
2. Check whether the flight mode/remote controller mode is P mode and whether the signal is strong. If the aircraft has entered the ATTI mode or another mode, the QuickShots function cannot be used. We recommend switching the remote controller back to P mode and ensuring that the signal is strong.
3. Check whether the vertical takeoff height is over 2 m. The QuickShots feature is not available if the takeoff altitude is lower than 2 m. Instruct the user to fly the aircraft above 2 m before using QuickShots.
4. Check whether you have selected the target and tapped Start. If the target is not selected or the Start button is not tapped, QuickShots cannot be triggered. Please check the QuickShots video as a reference:
5. Check whether the lighting conditions are good and whether there are obstacles around the subject If the light is insufficient or there are obstacles around, there might be a calculation error due to the visual element of the target distance. As such, the DJI Fly app will not be able to stitch Quickshots videos. When the light is sufficient and there are no obstacles around the target, keep an ample flight distance to prevent the influence of visual elements.
7. Refresh the aircraft and RC firmware version using DJI Assistant 2.
Please keep us posted.
what controller do you have? rc-n1?someone advised me that I have to "drop" the application to the background on my mobile and click on it again in the menu... and it worked (samsung s21 ultra)
I assumed since pictures and videos were stored directly to phone, these would be to.
Hi, if the storage is insufficient, QuickShots cannot be used (The QuickShots button is invisible). We recommend mounting a microSD card. Here are the recommended microSD Cards for Mini 2:
Hey, did you get a solution for this? I’m in the same situation just got a min2se and can’t get it to start. I also use my phone as storage and have no SD card, is there a way around this? Thanks
