DJI Gamora
Hi, djiuser_WsPAwDKyLL4b. Thank you for reaching out. We're sorry for the trouble with the calibration. Please follow the troubleshooting steps below:
1. Please check the Sensor Calibration Instructions in DJI Assistant 2. During calibration, keep the aircraft arms unfolded. Notes: Folded aircraft arms may obstruct the vision sensor, which may result in a calibration error.
2. Ensure that the monitor uses a straight-face screen. Curved screens are not supported. If the screen used is not a straight-face screen, please change or borrow a straight-face screen for operation.
3. Confirm the dimensions of the monitor being used. We recommend using a monitor larger than 14 inches. If the screen is less than 14 inches, the calibration may fail.
4. Please use a soft fabric (such as a cloth for glasses) to wipe the vision sensor lens of the aircraft. Wipe it several times until the lens is clean.
5. Please set the resolution displayed on the computer to the default value recommended by the system.
6. Open (https://www.dji.com/downloads/so ... sumer-drones-series). Check whether the DJI Assistant 2 is the latest version. If not, please download and install one.
7. After following the steps above, please reconnect the aircraft and the DJI Assistant 2 for reconnection and calibration.
8. If the issue still persists, please take a screenshot of the DJI sensor calibration failure and send it to us.
We hope this helps. Please keep us posted. |
