DJI Thor
Flight distance : 13602 ft
timensionless Posted at 7-27 22:20
Hello Thor and thank you for your reply!
However, the sound volume is not a result of any noise. The low volume during the first ca 10 seconds is present regardless of whether I move or not. And the level goes back to normal after a short time. I've tried several times but the result is consistent.
Hi there, after reviewing the video, here are the updates from our engineer. Please check, thanks.
For the low volume issue, it is suggested that before starting gesture recording you could adjust the system volume of the phone lower than 30%, and then start recording by gesture. Also, please check whether the volume recorded by other third-party apps have low volume issue or not. If the problem still occurs, please provide us the problem log and operation time.
For the gesture recording issue, based on the video, it shows that the device is already shooting and following. To better identify the problem, please provide us the DJI Mimo video recording for check. Thanks. |
