DJI Thor
Flight distance : 13602 ft
Hi there, thank you for reaching us. For the controller issue, please refer to the following and troubleshoot first, thanks.
1. It sometimes relates to the flight environment, we would suggest that you could fly the drone in an open wide area. Avoid obstacles e.g. trees, buildings, which may block the signal.
2. Check the antenna's position of the remote controller. Distance should be greater than height during flight, and please make sure the remote controller’s antennas are positioned parallel to and are pointed towards the aircraft.
3. Please make sure that the firmware and DJI Fly app has been updated to the latest version.
4. Besides, please check the transmission quality of the current flight channel, if needed, you can change to a different channel.
