primeshooter
Flight distance : 1433114 ft
I posted a good while ago now some images that I've taken with the Mini 3 Pro. Here is a refresher with new images because I've seen a lot of posts about photography with this drone recently and my tips will help those unsure.
Now I am not going to sit and explain to you about how I am the best ever aerial photographer; but I just wanted to show how capable this drone is if you carefully shoot and process. I see these questions all the time and I am well placed to advise as I am a regular photographer - you can find me on facebook as Steven Robinson Pictures if interested. Part of my values are to shoot the scene as naturally as possible for the most part, and to capture the highest fidelity data possible to use for PP later.
Caveats - Always Shoot in RAW. Always. (Hopefully I can disable jpg mode if they ever allow that). Shoot at Base ISO 100 whenever possible. Try not to deviate from here. This is where the highest dynamic range is, and the lowest noise, the best shadow and colour details exist here. Stay at 100, glue yourself to ISO 100. Use shutter speed to control the exposure only unless in exceptional circumstances. Always shoot in Manual mode, with the histogram activated. In contrasty light, always do at least a 3 shot bracket, ideally 5 and you can bin what you don't require later. Shutter speeds are wind dependant, but you can get away with being fairly cheeky as this is a small sensor. Always shoot in 12MP mode. This has several advantages - firstly a much higher dynamic range than the 48MP mode. If you need more resolution, simply stitch shots - easy to do in any software these days. If you need a wider FOV, stitch shots. The 48MP mode is a faux mode full of false colour and artefacts - master 12MP and you will win here. The great thing about bracketting in 12MP is that when you set a 5 frame bracket, you get x5 RAW files to exposure blend (I often pick two or 3 max) and blend them. Because they are all taken at the same time, there is no drone motion between shots, making blending easier.
Here are some single shots, some panos. All 12MP mode. All using the above advice. NB bare in mind these are not the full size files and will show compression on this website potentially.
Cala House, Loch Assynt
Tantallon Castle
Frandy River
Loch Eriboll
Loch Turret
Falls of Moness
Loch Buine Moire
Loch Bad a' Ghaill
Loch Tulla
Loch Lurguinn and Stac Pollaidh, Coigach
