AerialLens
I have been looking at all these "crack" posts, thinking ALL KINDS OF THINGS. Variables such as over-tightening, vibration, manufacturers design-process-material (issues go back to 2013 - wow). I have prop guards with the brackets that work like backing plates - so I thought "No big deal."
UNTIL NOW...
A guy in another forum completely lost a motor due to cracking, and he posted pictures that will have your mouth dropping to the floor. The whole base under the motor gave out. Yipes! I'm going to add to my backing plates with HVAC tape or something that absorbs vibration rather than transmit it through the shell. For those with a strong constitution, see the photos at phantompilots under a P3 thread beginning with the word, "Catastrophic."
I am not posting the direct link to the other forum here, as a courtesy to DJI. I really do not think these are "competing" forums though - if there is such a thing.
Bottom line here, in my opinion, is there is really nothing you can do other than reinforce the shell and/or use a backing plate under each motor the best you can. Good luck. We still have sweet machines that would cost a million dollars+ a few years ago, no doubt.
PS
I am also going to balance all my props now - which I thought was just plain silly to do on a P3...before now. Gotta do everything possible to either PREVENT vibration and stress energy, or ABSORB it.
PPS
If you already have a crack beginning on the shell somewhere other than inside the motor screw holes, it is a good idea to carefully drill a small smooth hole at the very end of the crack; this helps prevent further propagation of the crack by distributing the stress around a greater area. Old trick.
