djiuser_IjKebFRsAYYH
Flight distance : 1616693 ft
DJI Tony Posted at 3-5 23:33
Hi there. For aircraft with a 20-digit alphanumeric serial number (always prefixed with 1581F), The Remote ID serial number is the same as the drone serial number, and generally the same as the flight controller serial number, You can check the serial number of the drone in various ways,
1. Serial number on the box sticker
2. Serial number inside the battery compartment or elsewhere on the fuselage of the drone
Hi DJI Tony - I am trying to find the RID on my DJI FPV that has the 14 digit SN. I did all the FW updates today and the app update.... as far as I know I am completely updated.
However, I go look in the About section (do you mean in the Goggles v2, or in the app - they both have an About section) and there's nothing at all about a RID.
Do I have to do this outside? I am in my apartment. I did see a message that RID was active and had a green border when my phone is connected.
Why is this so hard ???
UPDATE:
DJI_Tony is giving out incorrect information! The RID is NOWHERE to be seen ... not in the goggles... not in the app. WHY WHY WHYWHWYHWEJ???
these are the TRUE steps (ANDROID)
1) get a reliable USB cable !
2) AT HOME: connect your Goggles, Drone, and RC to your phone (not PC - because it MUST work on the phone!) and do all the updates. App... firmware...and good luck with the GPS database - that failed to download about 10 times.
3) Test that everything is working and charge the batteries for a flight.
4) on another phone install "Drone Scanner" from the Play Store
5) OUTSIDE: get Drone Scanner started on the other phone, with your phone launch your drone and pause it up in the air... safety drum roll... WHILST you carefully put the remote controller down (careful with that throttle), lift the goggles up, look on the other phone, and make sure your drone shown.
6) Land... and your other phone will still show the RID.
7) TAKE A SCREENSHOT WITH YOUR REMOTE ID
??? OMG WHY ISN'T THE RID SHOWN IN THE GOGGLES UI ???
???? WHY IS IT SO HARD DJI ????
