Clouseau
Flight distance : 1070171 ft
Denmark
DJI Gamora Posted at 9-9 17:57
Hi, fans302fcd3a. Thank you for patiently waiting, we now received feedback from our relevant team. As per them, based on the video that you have provided, it is the normal logic. The trajectory height change between two waypoints will be affected by the height of the waypoints before and after the two waypoints. The flight route will curve between waypoints, so the aircraft altitude between waypoints may become lower than the altitudes of the waypoints during the flight. Hope this helps. Thank you for your continued support.
I have experienced the exact same issue - and it IS AN ISSUE, despite the auto-reply from the "relevant teams"!
If you program (as I did, which led me to this forum post) a flight where the 3 first waypoints are set to an altitude of 3 meters, and then sets the altitude for waypoint 4 to 10 meters, the mission fails because the drone tries to bury itself in the ground between waypoint 2 and 3. I can already guess the moderators reply, but do you really not see an error in this "normal logic"? |
