djiuser_uSyQEtKqcoMO
DJI Paladin Posted at 2023-9-6 19:05
Hi there. We're sorry for the trouble that this has caused. Please make sure to connect first all the components (DJI Goggles, DJI Avata, DJI Controller) then please go to Main Menu> Settings> Camera and click each setting you want to change. If you cannot select any of the settings, please try to connect each component via DJI Assistant 2 software and please update/refresh the firmware. If you still experience the same issue, please provide us a short video or screen recording showing the issue so we can check. Please keep us posted. Thank you.
I am experiencing the same problem. I can’t find a menu area where I can manually adjust the ISO value. I can only set the highest ISO, and the lowest value is 200. I’m also missing an area where I can change the shutter speed. I’m flying with Googles Integra and an FPV 2 controller. Any help on how I can adjust these values will be very much appreciated. |
