DJI Thor
Flight distance : 13602 ft
Hi there, may I know have you tried to refresh the firmware and try?
In addition, when taking off, do not select locations with a large difference in altitude. (For example, when the aircraft for waypoint adding takes off from a roof, and the replaying aircraft takes off from the ground, the aircraft will reach the maximum relative takeoff point altitude even if it has not reached the GPS altitude). If there are long-term replaying demands, as much as possible, do not get close to the maximum altitude when adding waypoints. In particular, do not make the first waypoint close to the maximum altitude. If the aircraft cannot return to the start point, the mission request will fail. The Waypoint Hyperlapse mission will get stuck due to the aircraft’s altitude limit.
