DJI Paladin
BetterBizTech Posted at 9-30 15:33
The problem is it tilts to 90 degrees but when I move forward or backward it tilts forward about 20 degrees not giving me a true topdown view
Hi there. Sorry for the late response. Basic principles for automatic spring back after the aircraft gimbal reaches the endpoint: The gimbal utilizes a speed avoidance design. The avoidance speed is set based on the angle at which the gimbal exceeds the joint angle endpoint. Generally, the spring-back angle is within 15°.
Using DJI Mini 2 as an example:
If the gimbal angle is -90°, the aircraft’s attitude angle in Cine mode and Normal mode will reach 25°. As the gimbal’s limit angle is -105°, the gimbal will at least bounce back by 10°. However, it would bound back about 15° due to safety considerations.
If the gimbal angle is -90°, the aircraft’s attitude angle in Sport mode will reach 40°. As the gimbal’s limit angle is -105°, the gimbal will at least bounce back by 25°. However, it would bound back about 30° due to safety considerations. The rebound angle may vary between different models. |
