DJI Thor
Flight distance : 13602 ft
Hi utlagr, we feel terribly sorry for the unpleasant experience that you came across. It is not our intention in any way to add more frustrations to our customers.
Please noted that RAW format is a kind of unprocessed and uncompressed format for original data obtained from the sensor. It is recommended to open images in this format with Adobe Photoshop. This cannot be opened directly through common software for viewing pictures. However, some picture viewing software (such as ACDsee) is able to parse and open a micro-image. The lateral resolution of the micro-image is 960 (the vertical resolution is determined based on the photo ratio). As such, we recommend using Adobe Photoshop to open DNG files as well.
Regarding the file transferring issues, you could also use a card reader to export the files from the SD card.
For the account updating issue, in order to better to assist, may I know which mobile model you use? Thanks.
