Basti_G
Hello.
Since the Spark flies shakily (only up/down), and sometimes will not rise, or palm start will result in landing/falling down, I was looking at the IMU-Values (before/after calibration).
If the drone is sitting somewehre the Accelaration sensors for X+Y show nearly 0, as expected. The Z-Axis however shows -1. What does that mean? Am I correct in the assumption, that the IMU thinks it's currently sinking, even thou it's just sitting somewhere (props off)?
I did try calibration trough Assistant 2, but it's stuck @95%. The screen howevers shows the values I am concerned about (see picture).
Does this indicate a damaged IMU? Any suggestions?
UPDATE:
Calibration trough Smartphone-App sucessful. Still flies shaky (up/down), and still has issues with palm start as described above. Still wonder if the Z-Axis should show value as described and seen in picture...
