DJI Tony
bleighty Posted at 1-20 19:36
Is the reason for doing 10 bit in efficiency mode because it is actually more efficient outputting 10 bit instead of 8 bit output? I have a use case where I want to maximize battery life. I don't care about 10 bit but if it is more efficient then that makes sense.
Hello bleighty,
Thank you for your patience.
Regarding the more efficient output you mentioned, could you please provide further details on what you mean, such as improvements in image quality or reductions in file size?
As for battery life, it is independent of the mode selected. The device uses a lithium-ion battery, which does not have a fixed lifespan. The battery capacity naturally degrades with usage, and the rate of degradation is significantly influenced by your usage and storage habits. With proper maintenance, the battery can remain functional for 2-3 years. However, some behaviours such as extended periods of deep discharge, can result in rapid cell damage and failure.
We recommend referring to the following article for battery maintenance guidelines to help extend your battery's lifespan: https://support.dji.com/help/con ... p;re=US&lang=en
Thank you once again for your support of the DJI Osmo Action 4. |
