ELMS
Unfortunately no. However I do want to make everyone aware about broadcast module issues. After hearing back from DJI they told me I would have to purchase a separate broadcast module as they were not going to provide a firmware update to the P4 Multispectral. I purchased the drone tag beacon. I attached it to the back of the gimbal as it was the only flat part on the drone. I went out for a test flight. I inputted a preprogramed flight at a height of 150 ft using the RTK module. The drone took off, it went past the 150 ft level to 400 ft. At this point I paused the program and tried to get control using sticks. At this point the drone continued to fly higher. At 500ft I tried to use the RTH function. GSPro at this point said there was an error. The drone continues to climbed past 700 feet before it lost connectivity. I have no idea were it ended up. I contacted DJI about the DJI about the fly away and sent them them the last flight data. According to them the drone had a constant height (200 m..that is over 600ft) and returned home. However their analysis does not show it landing. On top of that they told me it was pilot error and that the drone tag had interfered with downward sensors so it had a problem landing. I am not sure about the beacon interfering with the sensor system for landing but the rest of their response is just a made up story. I have been a pilot for 6 years and have flown many missions without incident so indicating pilot error is said on their part. They just replaced this drone and controller because I was have similar issues. They told me the controller was bad. This new drone had only 2 flights on it. My point is beware of adding the broadcast module as DJI even though they tell you to get one does not seem willing to help getting it up and running. I had to go and purchase a new drome which was the Mavic 3M because DJI has been slow walking my problem. They are now willing to give me a 15% discount. That would the make the cost of the P4 more that a new Mavic 3M and it comes with a module already in place. The last insult is I purchased this drone 1.5 months before they released the Mavic 3 M. You would think I would have been told to wait for the newer technology at a lower price. What a rip off. I am not happy with DJI at the moment. I have copied and pasted their response so you can see. At this point be careful purchasing a broadcast module!!!!!!...... Someone including FAA should be doing a better job of requiring unproven technologies. At the very least DJI should have done some testing....disgraceful on all parties and I am out $7000 and nobody cares.
Dora (DJI Support)
Oct 11, 2023, 18:41 GMT+8
Dear Customer,
Thanks for your patience.
This is Dora from the data analysis team, and I will be assisting you on this case from now on for related inquiries about data analysis.
For your case CAS-xxxxxxxxx-xxxx, we have finished the analysis, and the result is as follows:
1. The aircraft worked under GPS or Waypoint mode mainly in this flight. There was a constant height measured by the aircraft, which indicated that there was an extra object attached under the aircraft. The downward vision system was blocked by the extra object, and the performance and height control of the aircraft were affected;
2. T=05:43, H=198.5 m, D=50.1 m, RTH was triggered by the pilot via the remote controller.
3. T=06:07, H=202.8 m, D=0.4 m, the aircraft arrived at the home point and entered the landing mode. However, as there was an extra object attached under the aircraft, the aircraft couldn't land normally;
4. T=07:07, H=200.5 m, D=7.7 m, the flight record ended;
5. The last point: 28.077274, -80.5990519.
According to the analysis, the incident was caused by the pilot's misoperation. Please do not attach any extra objects under the water.
If you cannot recover the product and consider purchasing another one, we can offer you a 15% off discount for Phantom 4 Multispectral without the charger and remote controller.
Please kindly send us the following information if you would like to accept the offer:
Shipping address:
Contact name:
Phone number:
Should you have more questions about the result of the data analysis, please reply to this email directly. Then we will contact you via email in 1-2 working days.
Thanks for your support. Have a nice day!
Best Regards,
Dora
DJI Technical Support
Website:http://www.dji.com/support
YouTube:http://s.dji.com/DJI-Tutorials
