DJI Gamora
Malakai_UK Posted at 11-8 15:04
I can confirm the Aircraft Firmware: v01.00.0210 released on 08/11/2023 doesn’t fix the issue where importing content to iOS using the Apple SD card reader doesn’t show any content on the micro SD card. It can still be viewed when using the Files app and saved to the camera roll this way.
Hi, Malakai_UK. Thank you for reaching out. The DJI folder and file naming convention we currently use extends the JEITA & CIPA standard DCF naming convention, mainly to facilitate users' material organization and selection by optimizing the user's material presentation sorting, such as
1. Support custom directory/material naming.
2. Intuitively distinguish pano, timelapse, hyper-lapse, and other advanced function mode materials.
3. Added timestamp information directly in the naming.
4. Can directly distinguish materials shot by different cameras, such as lenses with different focal lengths.
However, due to the extensive expansion of the DJI folder and file naming conventions, there are a few compatibility issues (such as the Apple camera SD card adapter), so it may not be possible to directly use the system's built-in media library to browse and import materials. If you encounter this kind of problem, it is recommended to connect the storage medium to the target device "by file transfer" and enter the system "File" -> "SD card" -> "DCIM" to browse, download, and process materials. Thank you for your kind understanding. |
