Vented helmet mounts?
1002 4 2023-9-26
RanOutOfNicks
Singapore
Does DJI make a vented bicycle helmet mount for the Action 4?
If not, are the GoPro vented helmet mounts compatible?
Or any other brand?
Thanks!
2023-9-26
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We don't have this specific accessory for the DJI Osmo Action 4. However, we have the DJI Osmo Action mounting kit that can be mounted on your helmet. You may also want to check the Osmo Action Helmet Chin Mount and see if this will suit your needs. You may check the following link below. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
https://store.dji.com/sg/product ... nting-kit?vid=83481
https://store.dji.com/sg/product ... &from=store-nav
2023-9-26
RanOutOfNicks
Singapore
Thank you, but the chin mount works only on full face (typically motorcycle) helmets.
And the curved adhesive thingy is unlikely to stick to a vented helmet.
2023-9-26
kahixa
If DJI has released the Action 4 since my last update, it's possible that they have created specific mounts and accessories for it. You should check DJI's official website or contact their customer support for the most up-to-date information. GoPro mounts are generally compatible with a wide range of action cameras, including models from other brands. GoPro's mounts, like the Vented Helmet Strap Mount or similar products, may work with your DJI Action 4 if the camera's mounting system is compatible with GoPro-style mounts. Be sure to verify compatibility before making a purchase.
2023-10-15
lutzmix
use a gopro mount with original 3m pads or use sugru
2023-10-24
