DJI Gamora
Hi, djiuser_J7QEBta6zH0q. Thank you for reaching out. We're sorry to read that you're having trouble with your battery. Please follow the troubleshooting steps below:
① Ensure that the charging temperature range for the intelligent flight battery is within the required range;
② Ensure that an official charging cable and power adapter are provided and that the external power supply is normal;
③ Check the battery LED status, comparing to the battery LED status to confirm if the battery protection information is triggered by abnormal charging;
④ Please replace the battery to see if the charger is working normally;
⑤ Please replace the charger if possible;
⑥ After the above steps and found that using the same charger to charge multiple batteries, only one battery cannot be charged, the battery can be judged to be faulty, handled according to policy. If using the same charger, and found that all batteries cannot be charged, you can send back the battery and charger for diagnosis.
Hope this helps. Please keep us posted. |
