DJI Wanda
Hello, there. You can mount filters on the gimbal. Steps are below:
1. Hold the gimbal and camera module, rotate counterclockwise in this position, and remove the original lens cover;
2. After removing the original Lens cover, there will be raised clasp;
3. You can judge the front and back of the dimming mirror by the word ND on the outside, when it is upright, "NDxx" is directly above;
4. Aim at the correct installation port and rotate clockwise in this position to complete the installation of the ND filters.
You may make the decision based on your needs.
DJI Mini 3 does not support changing the aperture. |
