fansbe48dddc
There is no option to make the drone follow the GPS of the radio control.
When making videos on cars or boats or other vehicles, since the operator is positioned with the radio control on the vehicle, it happens that after traveling a few kilometers the app. notices that the home point is far away and evaluates, by calculating the percentage of battery remaining, whether it is time to return to the home point via rth, while instead both the operator and the radio control are located a few meters from the drone. You can certainly cancel the RTH but it clearly loses the subject you are shooting to cancel and on top of everything the emergency warning remains which distracts the shooting. I then calmly tried to do a test by updating the home point on the radio control position but the point where the radio is at that moment is recorded, so if it continues to move the RTH will be done on the previously recorded point. We would need an option to make the drone follow the remote control as happens on the Phantom or Inspire or to be able to disable RTH to drain the battery. |
