mmishra
I've got two batteries for my Phantom 4. One works as normal, it can be fully charged and works in the drone, but the other one can only be fully charged and will not power on. If I press the button once, all four bars light up, and in the charger hub a solid green light displays that it is completely charged. When I then go to use it in the drone however, I press the button once, and then hold it and the four bars light up in sequence but then a second later the four bars turn off and the circle button light stays on, but the drone does not power on. Any ideas on what's causing this issue?
