Osmo Action 4 Audio Adapter
4613 32 2023-10-23
Andreas Dueck
Switzerland
What we can expect...
I'm really looking forward to testing this thing!
2023-10-23
johansenfoto
Flight distance : 1180089 ft
Norway
I think it looks nice, and yes I want one but doesn't "need" one until summer
2023-10-23
Andreas Dueck
Switzerland
johansenfoto Posted at 10-23 10:59
Maybe you can also use this if you want to record music at a festival. Theretically the volume would be similar. It is possible that the sound is not suitable for this purpose, as it is intended more for recording the voice in the helmet. I'll look at that point too.
2023-10-23
johansenfoto
Norway
Andreas Dueck Posted at 10-23 11:30
I will think it will work as good as other adapter in all cases, and having the ability for longer record with charging is a pluss.
2023-10-24
Fishycomics
did htat go over that hard mode on button what it looked like to me
2023-10-24
Andreas Dueck
Switzerland
I didn't understand what you wanted to say.
2023-10-24
JodyB
Flight distance : 322005 ft
Fishycomics Posted at 10-24 03:15
It looks like it is intended to replace the door that covers the USB-C port on the camera.
2023-10-24
Andreas Dueck
Switzerland
JodyB Posted at 10-24 14:24
Thanks for the translation. Yes, it looks that way, but there doesn't seem to be any waterproofing. However, it wouldn't really be helpful because there are still two open ports.
2023-10-24
JodyB
Andreas Dueck Posted at 10-24 14:56
Yes, it reminds me of the cynova adapter for the original OA1. I have a couple of those. Makes me wonder if they are compatible with the OA4 to allow for analog mics and charge at the same time. What would your intended purpose for this adapter be for if you don't mind me asking?
2023-10-24
Andreas Dueck
Switzerland
JodyB Posted at 10-24 15:00
The adapter is advertised for motorcycling but I think there will be even more useful applications. Basically anything that has to do with a noisy environment. I'll test it out in great detail, maybe I'll even go to a concert again.
2023-10-24
JodyB
Andreas Dueck Posted at 10-24 15:13
Very cool ideas!! I'll be interested in the results for sure!!
2023-10-24
Andreas Dueck
Switzerland
Unfortunately, the Osmo Action 1 adapters are not compatible with the Osmo Action 4, the assignment of the USB C adapter is different.
2023-10-24
JodyB
Andreas Dueck Posted at 10-24 15:18
I suppose that answers that question. Saved me some time in trying to find where I stored those things. Much appreciated!!
2023-10-24
Andreas Dueck
Switzerland
I'm glad I was able to help, then my search, find and try out wasn't in vain.
2023-10-24
Fishycomics
this is it for sale soon
2023-10-24
Andreas Dueck
Switzerland
I think we'll have to wait until November... It's a shame that it won't be so easy to test the adapter on the motorcycle when its cold.
2023-10-24
JodyB
Seems its available to add to cart on the US DJI website:
https://store.dji.com/product/os ... -153591=&vid=153591
Seems charging is only supported when a microphone is in use?? Not sure I understand that move
2023-10-24
Andreas Dueck
Switzerland
JodyB Posted at 10-24 16:20
I thought the same thing too... Interesting move. Maybe the reason for this is that it is not “misused” for other purposes.
2023-10-24
Fishycomics
wonder if DJI hired CYNOVA again to  make one
2023-10-25
Andreas Dueck
Switzerland
Fishycomics Posted at 10-25 03:28
I didn't find any references to this, but it would make sense because they also built something similar for Insta.
2023-10-25
Andreas Dueck
Switzerland
I have now completed my first tests with the DJI Osmo Action Audio Adapter and I am very happy with the results.
The video is in German but there are subtitles.
2023-11-4
johansenfoto
Norway
You went really deep into this and did a good comparison.
For people that doesn't know German, just put on auto translate.
2023-11-4
Fishycomics
thanks for sharing.
2023-11-4
Andreas Dueck
Switzerland
I finally got around to testing the adapter on the motorcycle. The result is great!
2023-11-9
Aileronnn
Taiwan
Andreas Dueck Posted at 11-4 13:03
https://youtu.be/X6VxsJRkYv8
First of all, thanks for your testing. I believe your video helps lots of user including me.
But I'm not sure if I understand correctly...
According to 3:59~4:50 in English subtitle, the test result is DJI Audio Adapter can use on both OSMO Action 3 and OSMO Action 4?Same as rest of 3 products, right?
Also, I'm just wondering...
Have you ever tried OSMO Action 3/4 use the GoPro adapter(AAMIC-001) or NFlightCAM(SKU 556S) for recording ?
Cause I'm going to take some flying lessons in the US next year and I would like to record the audio from the ATC, but all the solution I found is for GoPro instead of DJI...
2023-11-10
Andreas Dueck
Switzerland
Aileronnn Posted at 11-10 13:13
First I want to say that I'm very happy that the video is helpful.
To your questions: The Osmo Action Audio Adapter can be used on both the Osmo Action 3 and the 4. With the 3 it only solves the problem with distorted sound with microphones that are too sensitive. There are alternatives for this part but I haven't found any that work as well. Unfortunately, simultaneous charging does not work with the Osmo Action 3, it is not supported by the Osmo Action 3! This is also the reason why DJI has declared the adapter only for the Osmo Actio 4.
For the Osmo Action 4, this adapter should outperform anything else that can be connected to the USB-C port.
Regarding your second question: You can't connect the GoPro adapter to the Osmo Action 3/4, you don't need that either. If you plug the 3.5mm plug of the NFlightCAM cable into the Osmo Action Audio Adapter, it should work perfectly. (Both adapters are TRS)
2023-11-10
Andreas Dueck
Switzerland
I found something when evaluating my last video which no one has reported yet.
The Osmo Action 4 has a limiter/compressor. I'll try out what we can do with it and whether it helps us.
If you have already experimented with it, I would be very interested in your results.
2023-11-14
Aileronnn
Taiwan
Andreas Dueck Posted at 11-10 14:07
Got it! It's clear enough for me.
Thank you very much!
2023-11-16
snorkel
Flight distance : 452592 ft
I got the adapter also, and the recording level is too low for anything other than in a helmet.  If you turn the gain up on the camera it introduces extra noise.
They really need to have an adapter with normal gain levels.   While I can use a splitter and a Boya by-k4 it does cause some strain on the USB C port on the camera.
The adapter is slightly bulky also and the 3.5mm port is on the front which if you want to use a mini mic with dead cat causes the dead cat to be in frame, if the they had better placement of the ports on the adapter that might have helped.
2023-12-6
Andreas Dueck
Switzerland
snorkel Posted at 12-6 07:02
If it helps you in any way, the USB C port on the Osmo Action Audio Adapter simply passes the signal through.
2023-12-6
snorkel
Andreas Dueck Posted at 12-6 15:00
Yep, I tried that and while it works it had the nasty side effect of making it stick out the side way to far...
I also tried increasing the gain on the camera but it adds a lot of noise/hiss to the audio.
It's great it works for motor vlogging and no one else  but would be nice if DJI had cynova make a normal version.
The adapter is nice as it locks in and protects the USB port from strain.
2023-12-8
djiuser_zNMffkixVdKL
Hi support team
I have been using the micro adapter. For that I removed the door of USB connector. But After using  I was not able to put the door in place.
Thank you to explain me how to put in place this door?
2023-12-9
Fishycomics
djiuser_zNMffkixVdKL Posted at 12-9 06:59
Hi support team
2023-12-9
