DJI Mic: Problem with Lightning adapter
717 1 2023-10-24
djiuser_903jRBFmb1Op
I have a problem with the Lightning adapter on my DJI Mic receiver. As soon as the adapter is attached, I can no longer switch from mono to stereo, I take the adapter off and it works. No damage is visible. If I switch to stereo without an adapter, the setting with the adapter is mono again.
2023-10-24
DJI Susan
Hi there, thank you for your reaching out. Due to the limitations of the iPhone’s Lightning port, only mono effect recording is supported when the DJI Mic Mobile Phone Adapter (lightning) or the DJI Mic Camera Audio Cable (3.5 mm TRS) is used for connection. Thank you for your understanding and support.
2023-10-24
