KIRILLNE
Russia
1)Thank you for adding 60 fps for the webcam mode, BUT they do not work, the picture does not change smoothly.
2) And in webcam mode, the camera gets terribly hot at the junction of the body and the gimbal, although in video recording mode it is usually not that hot even at 4k 60 frames, and as a webcam it works at 1080 30 frames per second. .. ,
3) maybe you need to reduce the load on the camera in this mode! since my phone transmits video from the camera via ADB without heating for 10 hours h.265, is it still possible to make the picture go to the computer like on the camera screen without additional load on it, or is the problem in the long-term continuous operation of stabilization in one place, is there heating there (the place where the camera rotates from left to right)?
Of course, I understand that this is not what your camera is for, but it would be cool to beat competitors like insta360 link, which on the same gimbal hardly gets warm when transferring video to a computer (
4) and another question about Microphone Mik 2, when connected via Bluetooth to a laptop and phone it shakes at different times, which creates interference when recording, while there are no such problems when recording to the camera and to the microphone’s memory, will this be possible? will be fixed in its new firmware
5) It would also be nice if it is impossible to remove this noise by connecting a microphone via Bluetooth - connect it via a USB cable directly to the computer as an external microphone, since now it is only visible as a flash drive
