neotint
I just ran a stress test, here in NYC with a new U.S. OP3. Not bad results considering the conditions:
My OP3 overheated and stopped recording after 89 minutes of 4K 60fps D-Log M, manual settings, HEVC — while also charging it via USB power pack.
It has Samsung Pro Plus 512 memory.
The screen was on the entire time at 50% brightness.
It was not connected to the MIMO app.
My device got quite hot: on the main body of the OP3 behind the screen, my RTD temperature probe registered 57C. The OP3 was indoors on a tripod in a window on a partly cloudy/sunny day. The outside temperature was 18C. The indoor weather was 24C with 50% humidity.
The OP3 manual says the operating temperature range is 0-40C, and the charging range is 5-45C. This test exceeded these temperatures, which is impressive engineering tolerance by DJI.
My recommendation, and product request:
2024 is expected to be the hottest year ever recorded. DJI and 3rd parties need to offer a heat sink solution that’s proven to be comfortable to hold while keeping the device within operating temperatures to avoid damage from thermal fatigue/thermal cycling over time.
This is the sort of DIY hack dwaynek made, using SSD heatsinks (lots of options available) is what I had in mind too:
https://forum.dji.com/forum.php?mod=viewthread&tid=307032
A sleeker heatsink like this might be more practical:
I'm looking forward to a lot of high quality long format content use with my OP3 and want it to last.
Update:
Strangely, after this first test, I noticed that my custom Slider Control setting set to Zoom had reverted to Gimbal. All other settings were as I left them. So odd.
2nd Test:
I let the OP3 cool down for a couple of hours and charged it up to 100%.I ran a second test in the same conditions, but just on it's own power, not plugged into a portable fast charge pack.
It was 53C after 90 minutes of recording. No overheating forced the recording to stop.
Not wanting to add to the thermal fatigue I stopped it since I doubt I'll be doing more than 90 minute travel shots.
To DIY a way to lower thermal fatigue I ordered some 3D Printer Heatsinks to add to each side on the left and right behind the screen but above the micrphone, on the metal base of the gibmal which seems to be the hottest area.
