DJI Wanda
djiuser_IwcGiwmsHNRR Posted at 10-22 08:23
Hi!
I have a problem with the installing the firmware to the GL300F remote control. I tried to update the firmware in my DJI GL300F remote controller, but something happened and it was not go to the end maybe, beacouse now the status led shows white color, and not connected to the drone. I tried to refresh the firmware again with the DJI Go 4 and the DJI Assistant 2, but it was not working, i tried the hard reset, but it was not working also.
Hi, there
We apologize for the inconvenience that you are encountering.
Please try the steps below:
1. If the remote controller firmware upgrade failed, try with another mobile device on the recommended device list and conduct upgrade again.
2. Press the C1, C2 and shutter button at the same time. Power off and then power on the remote controller. Link the remote controller to the device. Follow the upgrade step of the status bar.
If the issue still fails, please take a video showing the whole operating process.
You may save it through a shareable link like Google Drive and DropBox, then send the link here. We will check it out for you. |
