DJI Pocket 3 - Low Audio Levels
12
5363 53 2023-11-2
Coolhand
Flight distance : 102323 ft
DJI Osmo Pocket 3 Audio problem
I received my Creator Combo on 1-4-24. I updated the firmware on the camera and the mic 2. I ran some audio tests today and was disappointed. I have the camera audio level set to 100%. The audio level from the Mic 2 was very low. I then tested 32 bit float from the Mic 2. It was even lower. If I boost the audio to 400% in iMovie it is acceptable. The audio level from the internal mic was much better.  I am very disappointed and considering a return. I had high hopes for this tool and would hate to return it.
1-10 12:23
Coolhand
Coolhand Posted at 1-10 12:23
I found the problem. I had the “monitor” volume maxed out but I didn’t know about the “transmitter gain”.   I turned that up and the volume is good.
1-12 13:54
fansa6ff3a6c
The DJI Mic 2 was officially announced / released today. Along with it they posted a "recommended gain" guide. For most cameras, they suggest +9 db gain. I'll be testing this adjustment with the Pocket 3.
Link to the guide can be found here (or by navigating to DJI Mic 2 Downloads section, it is the last link listed)
https://dl.djicdn.com/downloads/ ... mera%20Setup_EN.pdf
1-17 19:09
fansca3b94b6
Hi, just received my DJI Mic 2 and am having the exact same issues with 32 bit float internal wav files coming out at extremely low volumes when playing them back on my Mac, either through FCP or elsewhere. I tried increasing the gain to +12 on the transmitter, and though helpful it's STILL very, very low, to the point where increasing it a further +12 dB in FCP still doesn't match up to normal recording volume using the camera's recorded video. Has anyone had any luck with this issue? It basically renders the back up recording useless for me if I can't match it up to the camera's recorded volume.
1-18 15:09
djiuser_ITbqYOIlCxmG
Flight distance : 162270 ft
fansca3b94b6 Posted at 1-18 15:09
No. I am afraid the Mic 2 is a bit of a let down and I no longer use it on my Pocket 3.
It is a shame that DJI hasn't acknowledged this as an issue and resolved it as I feel it will impact on their reputation and sales will drop off once the issue becomes a little more widespread.
1-18 17:47
Blellow
Flight distance : 1311056 ft
Solved. Swipe left from right screen, hit middle audio icon between camera icon and pro icon.  In that menu is TRANSMITTER GAIN. Increase value makes louder audio recordings for the dji mic 2. Cheers
1-18 18:57
fansca3b94b6
Blellow Posted at 1-18 18:57
No, this does not solve it for me. As I stated, I increased gain in the transmitter fully to +12 and I'm still getting very low volume compared to all other recordings.
1-19 06:09
Natural Sounds and Sights
For those reporting that the TX GAIN makes a difference... are you going into a camera via analogue TRS or digitally, via USB-C?
1-19 06:59
fansca3b94b6
Natural Sounds and Sights Posted at 1-19 06:59
I don't think there's a issue when audio is recorded through the TX and into the camera (whether it be Osmo Pocket or DSLR via RX), the issue is with the Mic's internal 32 bit recording when it is not connected to any camera. The wav files you pull off the TX itself are what have very low audio levels.
1-19 08:35
fansca3b94b6 Posted at 1-19 08:35
I agree. Interesting to see what people's perceptions, are, however. Yes, They are often -22dB!
1-19 09:04
fansca3b94b6
Natural Sounds and Sights Posted at 1-19 09:04
Yeah, I think most people are just using the Mics through a camera and don't bother with the internal recordings, which is maybe why this problem hasn't been extensively posted about? Nada on the YouTube reviews that touch on it though.
1-19 09:07
Blellow
You nailed it. Sorry for the mistake.
That is a big problem.
1-19 13:36
firatdede
Turkey
I wonder when DJI will solve this serious problem, are the authorities looking at this forum? It should be able to record sound in sufficient volume standalone without the main unit. Please DJI hear our voice.
1-21 02:35
djiuser_1W5GM8id6oTC
I was thinking on purchasing the Mic 2 transmitter, but I'm glad I read this thread.
Until DJI fixes this, the Mic 2 transmitter is not an option for me.
3-25 16:47
12
