Warnings Spoken in Chinese on RC Plus
1389 9 2023-11-8
Johnnokomis
Flight distance : 14031719 ft
Anyone else found other dialog spoken in Chinese? Who can translate this for me?
2023-11-8
DJI Thor
Flight distance : 13602 ft
Hi Johnnokomis, thank you for reaching out. The warning means 'RTK positioning is abnormal and positioning accuracy is reduced. Please fly with caution'. You could try to refresh the firmware to the latest version again to see if it could be solved.
At the same time, sorry for the inconvenience. We will also feedback this broadcast language issue to our engineer team to further check. Thanks.
2023-11-8
Panph
Flight distance : 5372365 ft
i have the same problem
for sure next firmware will solve
2023-11-9
Hoarfrost
Flight distance : 705974 ft
When I first got my Matrice M30 I also had the occasional Chinese message come across the controller. I went into the language settings and found it was set to "Default". Changing it to "English" fixed the problem.
I believe an update took care of it as well.
2023-11-11
AR_AirPrecision
Flight distance : 2660509 ft
Belgium
Hoarfrost Posted at 11-11 17:55
Still having the issue, even after RTK fmw fix...is the language Default to English the fix?
2023-11-29
Hoarfrost
AR_AirPrecision Posted at 11-29 05:28
Yeah - that worked for me. I had to go into the settings for the Android section of the controller and make sure English (and not default) was set. And also making sure it was set to English in the DJI app.
That fixed it.
2023-11-29
Johnnokomis
I too am still having this issue after updating. I went into the Android settings and removed every language except for English. I then went into Pilot 2 settings and even though it was already set to English (not default) I selected English again. Even still, I'm hearing what I assume is profanity by a sweet sounding Chinese lady when dealing with RTK.
2023-11-29
cessna1525
im having the same issue , its like that when you hot swap the batteries as well
2023-11-30
Johnnokomis
cessna1525 Posted at 11-30 08:44
Yep, I didn't even know about this one but sure enough. It didn't even used to give you an English warning when you hot-swap batteries. Now it yells at you and I don't have a clue what it's saying. In the US, the industry is all chasing NDAA compliant products. DJI is like "Hold my beer, watch this".
2023-11-30
AR_AirPrecision
Belgium
Feedback I received from DJI..."Bug" in current firmware. People from "sensitive sites" are looking un-happy about Chinese speaking hardware.
2023-12-1
