Montfrooij
Flight distance : 2560453 ft
DAFlys Posted at 12-28 01:18
the chemicals that make the fumes, outside paints are allowed a high voc content as they are used out doors and thus its hard to poison you.
Volatile organic compounds (VOCs) are emitted as gases from certain solids or liquids. VOCs include a variety of chemicals, some of which may have short- and long-term adverse health effects. Concentrations of many VOCs are consistently higher indoors (up to ten times higher) than outdoors
Ah yes.
And this is definitely a factor I'm considering. But I can't do much about it, other than keep the vents wide open.
With the recent winds, the air was almost constantly moving through the room, so that was a good thing.
I have 2 large gaps underneath 2 of the sheets of OSB of around 1m x 5cm. So that allows for a lot of air flow, plus some gaps near the other sheets and 2 window vents of (about) 1m in total.
That's all I could do. |
