gregg1r
![](https://forum44.djicdn.com/data/attachment/common/c5/common_13_usergroup_icon.png) lvl.4
US Law doesn't exist as such.
Under Federal law enforced by BATFE, you could make the interpretation that the electronic activation of the trigger makes the weapon being fired a machine gun.
The term “machinegun” means any weapon which shoots, is designed to shoot, or can be readily restored to shoot, automatically more than one shot, without manual reloading, by a single function of the trigger.
Previous court rulings on electronic triggers have affirmed that they are machine guns.
"I assume for example that the weapons on warbirds must be removed or disabled?" The disablement of araments on aircraft is due to the weapons being classified as machine guns. Same reasoning is used for those as well, more than a single round per pull of the trigger. Also the electric or pneumatic motor used to advance the round into the chamber.
Hand operated cranking system like the old gattling guns of the devises attatched to trigger guards, hand cranked are OK. Put a motor on it, it's now a machine gun.
