Mavic 2 Pro Remote ID Oddness
2685 7 2023-11-29
205Drone
Flight distance : 565801 ft
I updated my Mavic 2 Pro to the latest firmware, as well as my DJI GO 4 app on my iPhone 15 Pro Max.
I have several weird things going on.
1) Error, but, uhhhh, no error?
On the main screen, it says, "Remote ID error." I press on that to look at the error and it says it's functioning normally. Sooo, huh?
2) Once in flight for a bit, I can see the drone when searching for WiFi sometimes:
It's inconsistent. Sometimes, I see it and sometimes, I don't. It's not a distance thing as it's only at maybe 20 ft above ground.
3) RID Shows / Doesn't Show
When I look at the RID before flying, I can see the RID number. (left)
Once I go into flight, it disappears. Where'd it go? (right)
2023-11-29
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we do apologize for the trouble. Kindly please try to connect again your aircraft to the DJI Assistant 2 software and please refresh the latest firmware version. After that, please back up all necessary files and sync all your flight records and please reinstall the DJI Go 4 app on your mobile device then check if the issue persists. If yes, please provide us a screen recording showing the behavior so we can further check it. We will wait for your response. Thank you for your cooperation.
2023-11-30
205Drone
I used the app on my PC to ensure a fresh firmware and recalibrated everything. I deleted DJI GO 4 from my phone, reinstalled it, repaired it, and tested again. I still have the same problem. RID is there until I fly, then it disappears until I'm landed again.
It's also not showing up when I look for it in wifi settings.
I hope the video helps
2023-12-1
205Drone
205Drone Posted at 12-1 12:15
Knock knock
2023-12-4
205Drone
Hello? Can anyone please reply?
2023-12-6
Yaros1
Flight distance : 25188186 ft
Have you tried to take off outdoors with it?
Maybe because you have no GPS Remote ID deactivates on takeoff.
2023-12-6
205Drone
I tested outside and the RID intermittently shows up on my phone's WiFi. So, I guess it's working?
2023-12-11
DJI Paladin
205Drone Posted at 12-11 10:37
Hi there. Yes, once the remote ID appears in the "Available Networks" under the WLAN on your mobile device, it indicates that the Remote ID is broadcasting properly. Should you have other inquiries, feel free to contact us. Have a nice day ahead!
2023-12-13
