Sean-bumble-bee
Flight distance : 15997 ft
How can anyone diagnose the problem with that drone when you are not even the pilot and there is no flight log?
The video is too fragmented to be of any use other than to suggest the pilot flew too high, possibly too far and all in probably unsuitable conditions.
That said a negative height of 400m, let alone -640m, is highly suspect unless the drone's firmware has been hacked to allow it to break 500m.
If it isn't a malfunction of the drone the only way that I can think that, at apparent height, the indicated height could be so negative is if the drone was well above 500m and then lost contact. Then, after a while, regain contact.
At those heights it is quite likely the drone encountered
In such circumstances I have had a Mavic mini , a Mini 2 and a Mavic 2 Pro start a new .txt flight log on reconnection and, going by the flight log, have a significant negative height at landing. I do not rememebr what the apps showed, I watch the drone not the screen.
As for avoiding a 'repetition', don't fly like an idiot. |
