Sean-bumble-bee
Flight distance : 15997 ft
Dirty Bird Posted at 12-17 04:59
I have only have one DJI account. Litchi flights never synced with the DJI records. As you stated, you aren't logged into DJI when flying with Litchi. Also remember even DJI doesn't log when the bird is disconnected from the RC. All those long-range Litchi Waypoint flights with Phantom 3 Standards were beyond RC range, etc.. Hundreds of 40,000' or more Waypoint flights not counted. None of those flights would be logged even if Litchi did sync with DJI as the RC was disconnected.
I have requested many times, to no avail, that the Assistant program have a "Sync Internal Flight Logs" option. The bummer is ALL logs are recorded by the bird's internal flight recorder, regardless of RC contact. Even if you just power on the data is logged. DJI just never provided a way to sync them. You would think this would be a fairly simple addition? The Assistant has you logged into your DJI account. Should be no different than syncing flight records from an app except the internal logs would need to be decrypted by the server upon receipt. They would provide a lot of data for DJI. Pilots would benefit by having a better understanding of how many miles birds have actually logged. Someday perhaps....
"The bummer is ALL logs are recorded by the bird's internal flight recorder, regardless of RC contact."
In what follows I assume you are talking about the DATs on the drone itself.
I like logs, but I see an appreciable problem with syncing these drone DAT's.
For one thing, incomparison with the .txt flight records the drone DATs are HUGE.
The average size of my P3 drone DATs is 69,455,076bytes, I have lost a few during 'my time' through forgetting to download them and having old, uncopied logs over written. The largest is 314,580,992bytes.
Over the same time period the average size of the Go App .txt flight logs from my phones is 210,056bytes, I have have lost a few .txt flight logs.
I haven't bothered to download more that a few drone-DATs from the minis and m2p/z so it isnt worth working out averages.
The second problem is that the downloading, via USB, of the DATs from the drone is INCREDIBLY slow, at least with my equipment it is.
