Osmo Action 4 external mic bug
12Next >
6106 43 2023-12-18
Thiago Noronha
Flight distance : 586152 ft
Brazil
I use the external microphone, and in the first 3 to 4 seconds (sometimes up to 14 seconds) of recording, as soon as the camera is turned on, the external microphone is not activated, it only comes into action after seconds. I use the Boya BY-M3 wired microphone.
Can anyone tell me if this is a bug or some configuration?
2023-12-18
Fishycomics
the Power mode on will allow  external audio no issues, correct?  When we use Quickstart, that is a different story, I wait  till I see the green bar and then record. with Any external mic,   Action 3 & 4.
2023-12-18
Andreas Dueck
Switzerland
The recognition of the microphone is currently still buggy when you connect a USB-C microphone. With some microphones the recognition works after 2-3 seconds and with others it can take up to 15 seconds. The Boya BY-K4 adapter in combination with a TRS microphone works very reliably but you still lose the first 2-3 seconds. Maybe someone can recommend a USB-C microphone that works reliably. Unfortunately I can't help with that.
2023-12-18
Fishycomics
I have a rode wireless go, I have a godox, I have a fulaim, I have a Aluratek they all act the same. I do have an Apple USB C  to head set and acts the same with any of the ten other mics I own.  I say I see it like 5 seconds of QS all, unless you show a video of hte actual   use.  then maybe DJI can pass to the Relevant team for future evaulation
2023-12-18
Thiago Noronha
Brazil
Fishycomics Posted at 12-18 08:58
Fishycomics, thank you for the answer, now I know it's not a problem with my microphone. I use the camera on my motorcycle helmet and Quickstart is very important. I changed my Action 1 to Action 4 because of the timecode, but it's another thing that doesn't work correctly. Anyway, let's wait and see if DJI solves these problems.
Note: your videos have already helped me a lot with Action 1. Hugs directly from Brazil.
2023-12-18
Thiago Noronha
Brazil
Andreas Dueck Posted at 12-18 07:36
I bought the Boya BY-K4 adapter and I'm going to use it with my old Action 1mic (TRS) to see if it improves. Thanks for the tip, a shorter delay is better for my recordings with the helmet camera.
2023-12-18
Fishycomics
Thiago Noronha Posted at 12-18 09:59
you are very welcomed.  DJI has been notified over and over on things and  hope they can work it out.  I learned to simply  give a 5 count and  talk, but sometimes I get clipped on a vid here  and there. I wonder if the DJI wireless Mic 2 with bluetooth will be a fix for it?
2023-12-18
Thiago Noronha
Brazil
Fishycomics Posted at 12-18 10:14
Maybe the DJI Wireless Mic 2 doesn't have this delay problem, but for use on a helmet in adverse conditions it's not a good option. I prefer to make sure that the wire is connected, I believe that wireless is another variable for possible problems with sound recording (I mean in relation to the battery, disconnection...)
2023-12-18
Fishycomics
  it al depends on each persons situation
2023-12-18
Teddy65
Flight distance : 543169 ft
Same problem here with the Ulanzi AM18. I have to wait several seconds (up to around 15) til the green bar appears.
Another point is the low volume at which the sound is recorded. I have to turn the gain level extremely high so that something can be understood.
Thank God I can set auto level in my editing software. But it would be really nice if that wasn't necessary and the problems could be fixed with a firmware update.
2023-12-18
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we do apologize for the trouble. We will forward this issue to our engineers for further clarification. Kindly please provide us with the connection method you use (connection image or short video showing the connection method) and the original video file then upload it via Google Drive so we can check it further. Please keep us posted. Thank you for your cooperation.
2023-12-19
Thiago Noronha
Brazil
DJI Paladin Posted at 12-19 00:02
Hi, DJI Paladin
Here is a photo of the connection and a link to an original file with the mic delay problem.
Original file video - Google Drive - https://drive.google.com/file/d/1uUTvuqwoaU9hdRKmWcBSLthXJYdw5CpL/view?usp=sharing
2023-12-19
DJI Paladin
Thiago Noronha Posted at 12-19 02:11
Hi, DJI Paladin
Thank you for your response. We already coordinated this with our relevant team and we are now waiting for a response. We will surely keep you posted once we receive an update. We appreciate your understanding.
2023-12-20
DJI Paladin
Hi there. Thank you for patiently waiting. Considering these factors, it is recommended that you adjust the shooting sequence by powering on the camera before initiating the recording process, thereby ensuring optimal audio quality. In addition, If the external microphone supports internal recording function (such as DJI Mic), please enable internal recording simultaneously to ensure that there is backup audio available for future use. We appreciate your understanding.
2023-12-22
Fishycomics
written to the book now is hte answer above that is what the fix is as they will not correct
2023-12-22
Thiago Noronha
Brazil
Fishycomics Posted at 12-22 03:59
Unfortunately...
2023-12-22
Fishycomics
exactly,  till the next release camera this is not new  with gopro either took them a few models to get it corrected so shall DJI
2023-12-22
Thiago Noronha
Brazil
Could anyone tell me if DJI wireless Mic 2 with bluetooth solved the mic delay problem?
2024-1-4
Fishycomics
I be interested as well who   can  simply run a test  on that too see if htere is  no delays
2024-1-4
Natural Sounds and Sights
Fishycomics Posted at 1-4 13:34
No. It still takes several seconds to connect. 5-6 seconds, I'd guess from looking at it. Same exact issue on the Pocket 3, incidentally.
2024-1-5
Fishycomics
Natural Sounds and Sights Posted at 1-5 23:36
Thank you.    answers my question
2024-1-6
djiuser_IwfnYPPUpxmY
Flight distance : 28442 ft
Thiago Noronha Posted at 1-4 09:46
No. If you have the mic 2 connected via Bluetooth and using quick start to record the delay is around 7 seconds in my testing. Also if you are using quick start and leave a delay of around 15 minutes between shoots the DJI mic 2 will power off meaning you will need to physically turn the mic back on again and reconnect to the Action 4
2024-1-21
Thiago Noronha
Brazil
djiuser_IwfnYPPUpxmY Posted at 1-21 20:32
Do you mean that after 15 minutes of non use I have to turn on the Mic 2, turn on the Osmo Action 4, and reconnect manually by going to the OA4 menu....
If the camera is on the helmet, I will have to stop, remove the helmet and manually reconnect before taking the next video?
2024-1-22
Punkerage
Brazil
Thiago Noronha Posted at 1-22 01:51
This camera is not good for motovlogging at all. i really regret spending the money on this.
i've lost too much footage, for poor sound quality. going back to gopro unfortunately!
2024-1-22
Thiago Noronha
Brazil
Punkerage Posted at 1-22 18:36
I also thought that about the Osmo Action 1, but with patience I managed to get an excellent configuration to use on my motorcycle trips. Now, I hope to achieve the same with OA4.
2024-1-23
Punkerage
Brazil
Just to let everybody know, after the last update (https://forum.dji.com/forum.php?mod=viewthread&tid=297209), my camera consistently start the external mic in 2 to 3 secconds.
So its much better now.
2024-1-29
Thiago Noronha
Brazil
Punkerage Posted at 1-29 17:48
The big problem is that after about 15 minutes that the camera is off, the mic delay becomes long again.
2024-1-29
Thiago Noronha
Brazil
I rode my motorcycle 2,000km to go to the Brazil - Paraguay border to buy the Mic 2.
1. The 15 second delay in the mic 2 actuation remain the first time you use it.
2. After approximately 15 minutes, Mic 2 turns off by itself, so during the next recording it is necessary to turn on the camera and Mic 2 manually. In this case, the delay in activating Mic happens again.
Question: Is it possible to configure the Mic 2 that it does not turn off by itself?
In my recordings, I spend about 10 hours on the bike, every time I need to do a new video where the camera was off for 15 minutes, I have to turn on the camera (ok, that's normal), and turn on Mic 2 which is inside the helmet, this is extremely complicated to do with the bike in motion.
2024-1-29
djiuser_tWEa5NfuSPJq
I'm not trying to hijack this issue, but I'm not sure where else to post this...
I have not been able to get my osmo action 4 to recognise my DJI Mic 1, every time I try to connect it, it says "Mic 2 not found"
Surely the older mic still works with the new tech?
What do I have to do to fix it?
Thabks
2024-2-25
lutzmix
djiuser_tWEa5NfuSPJq Posted at 2-25 23:27
mic 1 is only for pocket2
2024-2-26
fansb839b6c1
Brand new Action 4 today 03/26/2024  using the Sennheiser MKE 400 with their supplied TRS to USB-C cable... not a problem with any other camera... being used in a RideShare reality show... Audio lasts about 4 seconds and then just goes mute!  Really bummed as I lost 4 segments filmed tonight.  Has to be a shotgun mic to pick up the back seat so DJI Mics are not the solution in this case!  What's going on DJI?  You haven't fixed this?
2024-3-27
Andreas Dueck
Switzerland
fansb839b6c1 Posted at 3-27 21:44
I assume that the error in your case occurs with the Sennheiser MKE400.
The first 4 seconds are recorded via the Osmo Action 4's internal microphones and when the handshake is complete and the switch to the external microphone is to take place, no audio signal comes from the MKE400.
I would check whether the MKE400 turns on at all (maybe only works with DSLR and DSLM cameras).
The included USB C to TRS cable could also cause the problem.
2024-3-28
djiuser_vB7rsMeLSR1z
Flight distance : 29892 ft
I have Osmo action 4 and Rode wireless go 2. It was doing the record sound for 20 seconds / not record sound at all. I've updated the firmware, but haven't had a chance to test it yet. Are DJI saying the bug is fixed?????
2024-3-31
Galeavia
Flight distance : 135614 ft
Bulgaria
So I have recently bought osmo action 4 and the original mic adapter that was recommended for motorcycle riding as it dampens wind noise much better. I attach 3.5mm mic to it sound quality is amazing but as everybody else has mentioned months ago... I have the same issue. Microphone becomes active after 3-4 seconds, in some cases about 14-15 seconds after I start recording... I already lost few good footage because of this. Is this not possible to fix with a firmware update??? This was mentioned 6 months ago!
2024-6-2
Fishycomics
its much better on the Pocket 3, so we all await that for the Action 5. guess it has to do with the Bluetooth version they use that htey can not   increase its start time
2024-6-2
schlod1234
Hi Guys, not sure if this belongs in this thread, but...... I use a USBC external microphone in my helmet. The last couple of rides I have been on, it seems the internal microphones on my Action 4
becomes active after a couple of minutes, my external helmet mic still functions but the wind noise is extreme, currently have my gain set to -10 with wind noise reduction set to standard, has been
perfect up to now, not sure what is happening, at this stage, I am unable to use any footage as the noise just drowns everything out
2024-7-7
DJI Natalia
schlod1234 Posted at 7-7 13:21
Hi there, thank you for reaching out and we're sorry for the trouble caused. May i confirm that you're using the digital USB-C microphones that supports 48K/16bit? Also, kindly refer to the steps below and check if the microphone is connected in right way.
if the microphone is connected as above and issue persists, kindly share us a screen recording or video showing the issues for us to check further on this
Keep us posted. Thank you for your understanding.
2024-7-8
Fishycomics
How are you    recording from the QS. or manual mode on. its best to be Manual Mode on so the Mic is always connected.  if you are using the QS ,it will  conenct differently  each  time
2024-7-8
schlod1234
DJI Natalia Posted at 7-8 02:58
[view_image]
On my ride to work this morning, all seems to be good again, I think the USB C microphone may not have been connected securely enough... I gave the mic a bit more slack and made sure it was pushed in fully to the connector, sound was good for whole 45 min trip, so hopefully resolved,.
Mike
2024-7-8
DJI Natalia
schlod1234 Posted at 7-8 15:45
Mike
Hi there, thank you for sharing us the update and we're glad that the issue has been resolved. Do not hesitate to contact us back if there's any additional inquiries.
Thank you for your continued support!
2024-7-8
12Next >
