ptmusicbox
Flight distance : 121562 ft
Portugal
DJI Paladin Posted at 12-20 00:56
Hi there. Thank you for reaching out and we do apologize for the trouble. Please upload the original video file showing the issue so we can check it further. Please follow the solution below to see if there are any changes:
1. First check the wind velocity in the flight environment: The stabilization effect will be affected by strong wind. We recommend changing to another environment or waiting for some time before taking off again.
Hi there Paladin
Thanks for the answer.
1. Related to the wind speed, I have a personal limit which is around 30kph of wind gusts because of the fear I have of a flyaway or damaging it, but having the Mini 2 a Level 5 resistance that won't be a problem I think, as it is rated to a maximum of 38kph if I'm not wrong.
Also didn't have any "strong wind" alert while flying and noticing the horizon tilt issues.
2. OK yes, I understand what you're saying. Well, I'm not an expert with drone footage but I've already seen a few videos on YT with tips about how to fly smooth and create some good vids, that might not be the problem here. I also tested with Cine and Normal modes, if that matters.
3. All propellers installed are the original ones that came with the drone (same batch numbers). After a visual inspection I can't see any deformation, nicks, dents or any other kind of "major" damage. What I can only see is a tiny lack of paint or erosion at the tip of a pair of blades (FWD LH). Haven't noticed anything different with flying though, but I don't know if this might be related to the real issue (horizon tilt). Got my doubts! Or is it?
4. Installed the DJI Assistant 2 and did the refresh of the last FW.
I'll replace the pair of blades I mentioned for some new ones I have from the combo kit and test it at the next opportunity.
Thanks once again |
