GTHero
Flight distance : 1832372 ft
While testing my new drone, I set the loss-of-signal instruction to 'hover'. This is what happened:
1. When the image signal dropped to zero mbps (or very close), the drone stopped responding to commands and began to hover.
2. At the same time, however, the RC signal remained solid (different frequencies).
3. Strangely, throughout the hover I still had a reasonably clear video image with the bitrate ranging between 0 & 2 mbps. At no point did my video feed stop or disappear.
4. Not only was the drone unresponsive to joystick controls, pressing the RTH button also had no effect.
5. When the battery eventually dropped low enough, the auto RTH was triggered and the drone returned.
The above scenario happened twice - at two different locations. Except during the second occurrence I altered the angle of the controller while the drone was hovering, which caused the video bitrate to increase to 3 mbps - when all of a sudden my control returned.
So, we have an odd situation where the RC signal is solid, and the video image, whilst poor, is still present, yet the drone won't respond. Under normal conditions the drone is quite flyable with video under 3 mbps. Yet once the trigger occurs, and the drone begins hovering, it would seem that the video bitrate needs to rise to at least 3 mbps for it to disengage. Can anyone confirm that?
My main concern, however, is the drone not responding when I press the RTH button on my controller. I knew it would return eventually - when the battery ran down, but the fact that I couldn't get it to come back when I wanted it to, meant that a significant portion of my flight had been wasted - quite unnecessarily.
I don't think the hover setting (on loss of signal) should disable a manual RTH if the RC signal is still present. What are your thoughts? Has anyone else had a similar experience?
And on a related topic: Does anyone know why the Avata uses 5.8 Ghz (only) for the image feed? Away from wi-fi interference, 5.8 Ghz will almost always be weaker than 2.4 Ghz.
