vaughst
Flight distance : 26125 ft
fansfe82067d Posted at 1-11 05:05
Discussed elsewhere already, but in brief, if you turn on the "audio backup" feature in the settings (current firmware required) you can record the internal mics to a wave format file and the Mic 2 will be recorded to the AAC component of the video file. But, due to an annoying bug or a design error, the internal mics will be recorded in mono on the stereo wave file, so you won't get a nice stereo ambience behind your mono wireless voice. Just mono of internals and mono of the wireless mic. If you want stereo ambience to go with the wireless mic audio, use any other wireless mic that has a USB-C receiver, connected to the USB-C port of the Pocket 3. Then the internals will be recorded to the wave file in stereo, and the USB-C connected wireless mic will be recorded in mono (if only one mic in use) or in stereo (if it's a set of two wireless mics). Kind of daft that the Mic 2 is the only wireless mic not compatible with this function...
Ah sorry this has previously been discussed. Ok, that's kinda annoying but I'll try that as a work around. Cheers. |
