When I insert a fully charged battery in Mini 3 Pro, it turns on immediately, with « on » sound, gimbal stabilizes, left led blinks. DJI Fly show 0 as left flighttime, shows « communication error with battery », batteries cells and serial are unavailable in in settings. M3P does not take off.
Same behaviour with 3 other fully charged batteries (so I guess problem is on M3P's side).
Switching Mini 3 Pro off shows led extinguishing in a row as usual, right led blinking as if it’s been properly shut down. But then left led blinking, Mini 3 Pro automatically powers on again.
I need to remove battery to shut Mini 3 Pro down.
Mini3Pro firmware & remote refreshed using DJI Assistant 2 (Consumer Series Drones), did not help.
This Mini 3 Pro used to work fine, no crash. Started to do that today.
I also have a Mini 2, turns on and off nicely.
Hello, there. We're sorry for the inconvenience. May I confirm if this happens with all of your batteries? If so, please send your aircraft and batteries via this link. Please feel free to keep us posted on the latest progress.
@flydronesbg : No, I can't fly. Problems look similar, but aren't exactly. You have to press the button to start. I don't, inserting the battery turns drone on without touching anything.
Hello, there. Considering this phenomenon happens with every battery, it's recommended to send your aircraft for further testing. If you wish to send the drone for service, you may use this link. Thank you for your cooperation.
