Blackbuckone
Flight distance : 68967 ft
Labroides Posted at 1-17 06:39
Warranty means zilch, if an item suddenly goes to pot just after a warranty is finished, the company making it are obliged to repair or replace if this is within a reasonable time and as long as there has been no abuse or modifications.
You are fooling yourself.
You have no idea how long the drone was out of warranty.
It could be anything from 1-7 months.
If the company would provide warranty replacement for some time past the warranty period, why state a time period for the warranty.
In this case everything was working fine then it dramatically and fatally stopped, logs prove this so DJI should, once investagted, come to an agreement suiting both parties.
Again you don't know what you are talking about.
You hadn't examined the flight data and were just accepting the OP's brief description with no details.
The data doesn't have anything to indicate that there was a problem that would have been a warranty issue (if the drone was still in warranty).
It looks like battery disconnection was the most likely cause, but without the drone, there's no evidence to tell why.
Perhaps the battery wasn't securely fitted.
Perhaps it was swolen and pushed itself bacl.
Who knows? Not you.
Items aren't supposed to go unserviceable right after a warranty has ended, we have the Sale of Goods Act in the UK protecting people from things like this.
Since you have no idea what caused the incident, you can't say that the drone became unserviceable.
You can't say that it happened "right after a warranty has ended", and no matter how long outside the warranty period, it was still out of warranty, no matter how confidently you suggest otherwise.
And somehow I think your UK consumer laws have no relevance in South America.
Firstly, thank you for your over the top rant, which you seem to do quite regularly on here.
The OP never said they were in SA, which of course makes a difference.
But hey, you carry on acting like it's your own personal forum. |
