Boommusic
DJI Susan Posted at 1-21 02:31
Hi there, I am sorry for the unpleasant experience. May I double confirm if you have tried to download the DJI Mimo app from our official website to see if it can be installed?
If it can not be installed due to compatibility issues, you may try to borrow a phone that could work with the DJI Mimo to activate the unit first, then you can use the device without a phone.
However, features such as histogram or overexposure alert function option, Glamour Effects, live-streaming, will not work without the DJI Mimo app. And if you need to download the files that the Osmo Pocket 3 shoots, you may need to remove the SD card or connect it to the computer to export the files. Therefore, you may consider if you would love to keep the device. Hope for your kind understanding.
Thank you for your suggestions.
Yes, I have downloaded the official app from the official site (several times even). Unfortunately the app doesn't open or work.
Indeed, I also thought about at least activating the camera using someone else's phone. It seems a sad loss of opportunity if I have no access to functions without a compatible phone. I have wanted this camera for a long time, now I finally have it and then this enormous disappointment.
I didn't bother to check for compatibility prior to purchase, because I have such a common, normal, current phone that has never been an issue with any software or application.
Why doesn't DJI fix compatibility issues with Galaxy phones? All other (Android) apps work wit Galaxy phones, so it should be possible.
Thank you again. |
